  • 1 Vote(s) - 5 Average
Wheel hub bearing removal
(16-01-2019, 05:42 PM)Steve Jones Wrote: A short length of tube of a similar(ish) OD to the bit of the bearing inner that's visible is what I use. Insert tube from rear of bearing carrier, light tap on end of tube, bearing out. They aren't held in place particularly tightly.
Thanks Steve, I was afraid of seeing balls across the garage floor!
Wheel hub bearing removal - by Biddlecombe - 16-01-2019, 05:30 PM
RE: Wheel hub bearing removal - by Steve Jones - 16-01-2019, 05:42 PM
RE: Wheel hub bearing removal - by Biddlecombe - 16-01-2019, 05:44 PM
RE: Wheel hub bearing removal - by Steve Jones - 16-01-2019, 05:48 PM
RE: Wheel hub bearing removal - by Chris KC - 16-01-2019, 05:50 PM
RE: Wheel hub bearing removal - by Biddlecombe - 16-01-2019, 06:16 PM
RE: Wheel hub bearing removal - by Tony Press - 16-01-2019, 10:18 PM
RE: Wheel hub bearing removal - by Biddlecombe - 16-01-2019, 06:33 PM
RE: Wheel hub bearing removal - by Chris KC - 16-01-2019, 10:40 PM
RE: Wheel hub bearing removal - by Bob Culver - 16-01-2019, 07:19 PM
RE: Wheel hub bearing removal - by David.H - 16-01-2019, 08:14 PM
RE: Wheel hub bearing removal - by Biddlecombe - 17-01-2019, 12:43 AM
RE: Wheel hub bearing removal - by Biddlecombe - 17-01-2019, 12:53 PM
RE: Wheel hub bearing removal - by Bob Culver - 17-01-2019, 01:48 AM
RE: Wheel hub bearing removal - by Terrytuned - 17-01-2019, 12:37 PM
RE: Wheel hub bearing removal - by Biddlecombe - 17-01-2019, 06:47 PM
RE: Wheel hub bearing removal - by Biddlecombe - 18-01-2019, 12:50 PM
RE: Wheel hub bearing removal - by Steve Jones - 18-01-2019, 01:29 PM
RE: Wheel hub bearing removal - by AustinWood - 18-01-2019, 02:35 PM
RE: Wheel hub bearing removal - by Tony Press - 20-01-2019, 10:54 PM
RE: Wheel hub bearing removal - by Biddlecombe - 20-01-2019, 11:34 PM
RE: Wheel hub bearing removal - by Tony Press - 20-01-2019, 11:48 PM
RE: Wheel hub bearing removal - by Biddlecombe - 21-01-2019, 02:29 PM
RE: Wheel hub bearing removal - by Steve Jones - 21-01-2019, 04:57 PM
RE: Wheel hub bearing removal - by Biddlecombe - 21-01-2019, 06:53 PM
