I got the dynamo backlash down to 3 thou and also machined up some slotted bolts to hold it on. Am going to make up a pointer and make a TDC mark on the front of the engine since I realised it will be impossible to look down on the flywheel when the engine is in the car to see what the timing is doing. Am more interested to see what the timing jitter is like at idle when everything is running.
Simon
RE: What have you done today with your Austin Seven - by jansens - 16-01-2019, 08:14 AM
