Stripped the carb on my Ruby today Zenith 26 VA found no filter on the pipe bolt going into the carb and some one had soldered a new nipple on to the pipe and half filled the pipe with solder so that the pipe inside diameter was cut down by half  Sad
Why can't people do the job right
RE: What have you done today with your Austin Seven - by rubyman - 07-01-2019, 07:01 PM
