Took the RN (late 1932) out for a spin after adjusting the clutch.  Engine / gearbox out (it was only -4 deg C)  made a thicker spacer ring which fits between the clutch fingers and the bearing pressure plate, all back in and the run was OK. There are several anomalies with my setup -
The clutch withdrawal collar is for a 1933  and the gearbox top is marked
2   R
3   1       However the gears  are
R    2
1    3
I can now engage 1st without a 'graunch'.  I'll give it a longer run before the floor panels / carpets are replaced.
BobH
RE: What have you done today with your Austin Seven - by bob46320 - 07-01-2019, 01:43 PM
