Push rod rear brakes
I have recently 'inherited' an Austin 7 chassis with unusual brakes and was wondering if anyone can help me with identifying where they are from.
I'm only new to the Austin 7 and still on the steepest part of the learning curve, so would appreciate any wisdom you can share.
The brakes appear to be solid push rods that run back along the chassis rails to the rear brakes - photos below.
The only reference I've been able to find to any sort of push rod style brakes on an Austin 7 was a hybrid rod and cable system that ran a single rod back to somewhere near the rear chassis cross member then cables to each wheel.
This chassis appears to have been extensively modified during its life with welded on reinforcement, a strange boxed in cutout in the rail on the front left under the engine, plenty of muck and grime, and no obvious chassis numbers to find - yet.
regards
Andrew
Push rod rear brakes - by agmatthews - 06-01-2019, 01:20 PM
RE: Push rod rear brakes - by John Cornforth - 06-01-2019, 01:39 PM
RE: Push rod rear brakes - by AustinWood - 06-01-2019, 02:02 PM
RE: Push rod rear brakes - by Chris KC - 06-01-2019, 02:11 PM
RE: Push rod rear brakes - by Ian Dunford - 06-01-2019, 03:49 PM
RE: Push rod rear brakes - by Zetomagneto - 06-01-2019, 06:05 PM
RE: Push rod rear brakes - by Bob Culver - 06-01-2019, 07:18 PM
RE: Push rod rear brakes - by Chris KC - 06-01-2019, 08:19 PM
RE: Push rod rear brakes - by Dennis Nicholas - 06-01-2019, 08:19 PM
RE: Push rod rear brakes - by Charles P - 06-01-2019, 09:11 PM
RE: Push rod rear brakes - by agmatthews - 06-01-2019, 09:35 PM
RE: Push rod rear brakes - by Zetomagneto - 06-01-2019, 09:44 PM
RE: Push rod rear brakes - by Tony Press - 06-01-2019, 10:31 PM
RE: Push rod rear brakes - by agmatthews - 07-01-2019, 06:51 AM
RE: Push rod rear brakes - by Tony Press - 07-01-2019, 07:23 AM
RE: Push rod rear brakes - by Erich - 07-01-2019, 05:37 AM
RE: Push rod rear brakes - by Hedd_Jones - 07-01-2019, 01:13 PM
RE: Push rod rear brakes - by Dennis Nicholas - 07-01-2019, 01:16 PM
