06-01-2019, 10:02 AM
(06-01-2019, 09:17 AM)Paul Nott Wrote: Hi All
Slightly confused regarding the fitting of an isolator switch to my special.
Initially I was planning to fit a Lucas unit to the dash next to the starter button, breaking the + positive circuit (6v neg earth system).
However the instructions state fitting to the earth circuit, the battery is fitted underslung passenger floor some way from the dash.
Question is, would I then have to run the negative earth cable from the battery to the isolator and then to earth ?
A friend with a Seven has suggested fitting to positive circuit on dash prior to push start button, any thoughts.
Big green knob negative post terminal switch - just mount on the battery post then put the lead from this to the normal earth connection. Around £9 on eBay.
