Distributor failure identified
The Bosch replacement had no spark either initially, is that correct?
The Accuspark unit is mass produced and the very low price reflects this, some issues are inevitable amongst such production, as you will be aware. Yours and the one pictured above are the only mechanical failures I am aware of - so far.
Most of the electronic issues I have experienced with these units can be drawn down to set up, the unit will fry if any connections are loose or poor.
What Ω protection does your current coil provide? Anything below 1.5 will eventually destroy the trigger units, I have found.
If the trigger has run well for 500 miles I would suggest that something else has upset it, rather than faulty workmanship this ties with the Bosch unit not sparking early on either. I would suggest looking carefully for a wiring fault somewhere in the loom or switches, if you intend fitting the replacement Accuspark unit, otherwise you will be facing similar issues not too far down the line again.
My advice comes from fitting over 50 units now, hope you find it helpful.
Distributor failure identified - by Andy Bennett - 02-01-2019, 07:07 PM
RE: Distributor failure identified - by Ruairidh Dunford - 02-01-2019, 09:12 PM
