01-01-2019, 04:51 PM
Andy,
When using the wire from battery to coil make sure the coil is isolated by making sure the ignition is off or, better, the feed completely disconnected.
Do you have a new spark plug to try?
Are you using different spark plug leads when swapping between the distributors, if not, consider making up a new king lead.
Have you tried to tow start the car?
