29-12-2018, 11:20 PM
(22-12-2018, 10:03 AM)Ruairidh Dunford Wrote: Dicky,
the newly manufactured 5.67 c/w is a smaller diameter than the original one and you should be able to get one to fit your existing back axle casing.
Thanks for that, the problem is down to the pinion side of things, the pinion bearings and torque tube are a slightly different design, the driveshafts are also slightly larger diameter, so will hopefully be more suited for trials use in the future..
