29-12-2018, 07:34 PM
I have been using the silicone gasket for about six-months now in a standard pressed steel cover, and I can report that this has not yet leaked! I have done several thousand miles in the interim.
The problem with the cork is a square profile is being fitted into a rounded channel, it has to be trimmed to fit and the success or not depends on how well the trimming is done, I had a reasonable success, with sealant, but so much easier using the silicone gasket. I glued the silicone gasket with dabs superglue to hold it in place when fitting the cover in place.
Will be using this on my other engine in due course.
