John Williams and 12 volts
I have 2 terminals on the outside of the case of the dynamo marked 'F' and 'D'.  To which terminals do these 2 normally connect inside of the dynamo?  I assume they run to the 2 main brush terminals but which way round?  This dynamo was in pieces when I got it and Woodrow doesn't show the connections.  On the pic below the F is to the left but how do you know which of the 2 brushes it goes to.  One is on a metal bracket and the other is on a sort of Bakelite one.
I have 2 starting handle nosecones to weld up and then I can get onto making the 2 drop links for the lowered suspension, assuming I can find enough steel on the shelf.
Thanks.
Rob (on the home stretch
[Image: image014.jpg]
[Image: Dynamo%20wars%205.jpg]
Can I safely assume that the Earth brush is the one on the steel bracket and the 'D' brush is on an insulated bracket.  Sorry if this sounds like a silly question but I don't want to kill the dynamo today! Page 205 of the Green Book shows a picture but mine is covered with dirty finger marks.
John Williams and 12 volts - by cardiffrob - 27-12-2018, 01:00 PM
RE: John Williams and 12 volts - by John Mason - 27-12-2018, 04:09 PM
RE: John Williams and 12 volts - by cardiffrob - 27-12-2018, 04:45 PM
RE: John Williams and 12 volts - by John Mason - 27-12-2018, 04:55 PM
RE: John Williams and 12 volts - by cardiffrob - 27-12-2018, 06:42 PM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 09:34 AM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 11:49 AM
RE: John Williams and 12 volts - by AustinWood - 28-12-2018, 12:50 PM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 02:09 PM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 04:51 PM
RE: John Williams and 12 volts - by john williams - 29-12-2018, 12:23 AM
RE: John Williams and 12 volts - by Zetomagneto - 29-12-2018, 10:23 PM
RE: John Williams and 12 volts - by cardiffrob - 29-12-2018, 08:47 AM
RE: John Williams and 12 volts - by Bob Culver - 31-12-2018, 11:21 AM
