John Williams and 12 volts
I've met John a few times and he gave me some good advice about his 12V conversion to go alongside the Bristol A7 Club webpage.  I'm currently trying to get my car finished off, if only to get it running enough to drive round the garden.  I'm unemployed so a new 12 volt kit is out of the question.  I have everything else in 12 volts available from Morris 1000s so I'd prefer to avoid the cost of equipping with 6 volt bulbs etc.
I've got a very late C35 dynamo all cleaned up but wanted to check the info out before I fire the car up again.  At the moment I think that the 3rd brush has to be removed and an added cable strung between the screwed terminals of the old 3rd brush and the earth brush which is shown in Woodrow as "Negative (earth) brush".  The 2 other brushes remain exactly as Austin designed them?
The mathematics mentioned by John don't seem to add up.  1.6 Ohms plus 3.4 ohms would be 5 ohms.  Am I right in aiming for 5 or for 6 ohms?
Lastly, I can find the F and D terminals on the control box but how do I ensure I have the righ terminals as they come out of the dynamo itself?  Mine has a block with 2 wires held by grub screws.
Many thanks
Rob Thomas
.jpg   DSC00621.jpg (Size: 410.7 KB / Downloads: 609)
John Williams and 12 volts - by cardiffrob - 27-12-2018, 01:00 PM
RE: John Williams and 12 volts - by John Mason - 27-12-2018, 04:09 PM
RE: John Williams and 12 volts - by cardiffrob - 27-12-2018, 04:45 PM
RE: John Williams and 12 volts - by John Mason - 27-12-2018, 04:55 PM
RE: John Williams and 12 volts - by cardiffrob - 27-12-2018, 06:42 PM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 09:34 AM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 11:49 AM
RE: John Williams and 12 volts - by AustinWood - 28-12-2018, 12:50 PM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 02:09 PM
RE: John Williams and 12 volts - by cardiffrob - 28-12-2018, 04:51 PM
RE: John Williams and 12 volts - by john williams - 29-12-2018, 12:23 AM
RE: John Williams and 12 volts - by Zetomagneto - 29-12-2018, 10:23 PM
RE: John Williams and 12 volts - by cardiffrob - 29-12-2018, 08:47 AM
RE: John Williams and 12 volts - by Bob Culver - 31-12-2018, 11:21 AM
