  • 2 Vote(s) - 1.5 Average
Gearbox thrust washer
#21
Sounds like you've got an earlier (3sp) clutch release shaft as the earlier boxes used a cotter pin to secure the pedal. The 4 speed boxes are not so machined and use a pedal that's secured by a pinch bolt - it makes setting up the relationship between the pedal and the free play that much easier. I don't suppose it's a problem if you have the later pedal.
Gearbox thrust washer - by jansens - 17-12-2018, 07:49 PM
RE: Gearbox thrust washer - by Chris KC - 17-12-2018, 08:39 PM
RE: Gearbox thrust washer - by jansens - 17-12-2018, 09:38 PM
RE: Gearbox thrust washer - by Chris KC - 17-12-2018, 10:55 PM
RE: Gearbox thrust washer - by jansens - 19-12-2018, 03:49 AM
RE: Gearbox thrust washer - by Chris KC - 19-12-2018, 01:20 PM
RE: Gearbox thrust washer - by Reckless Rat - 19-12-2018, 02:08 PM
RE: Gearbox thrust washer - by Chris KC - 19-12-2018, 02:27 PM
RE: Gearbox thrust washer - by jansens - 19-12-2018, 08:48 PM
RE: Gearbox thrust washer - by jansens - 20-12-2018, 07:29 PM
RE: Gearbox thrust washer - by Chris KC - 20-12-2018, 08:06 PM
RE: Gearbox thrust washer - by jansens - 20-12-2018, 09:54 PM
RE: Gearbox thrust washer - by Reckless Rat - 20-12-2018, 10:24 PM
RE: Gearbox thrust washer - by jansens - 21-12-2018, 08:19 AM
RE: Gearbox thrust washer - by Dave Mann - 21-12-2018, 10:07 AM
RE: Gearbox thrust washer - by Reckless Rat - 21-12-2018, 11:22 AM
RE: Gearbox thrust washer - by Chris KC - 21-12-2018, 11:30 AM
RE: Gearbox thrust washer - by jansens - 21-12-2018, 11:33 AM
RE: Gearbox thrust washer - by jansens - 22-12-2018, 09:11 PM
RE: Gearbox thrust washer - by John Mason - 23-12-2018, 10:54 AM
RE: Gearbox thrust washer - by jansens - 23-12-2018, 07:47 PM
RE: Gearbox thrust washer - by Reckless Rat - 23-12-2018, 11:14 AM
