20-12-2018, 09:54 PM
Yes, am finding the description in Woodrow a little hard to follow. Has anyone made and used one of those tools? I guess the idea is it allows you to easily push the ball town into the hole and hold it there when you rotate it. Then when you put the shaft through a quick tap on the end of the shaft will dislodge the tool and let the shaft slip into it's place.
