20-12-2018, 12:35 PM
(20-12-2018, 10:04 AM)Paul Nott Wrote: Thanks for the reply, I will investigate possible fuelling problem.
One thing I would say is yes the magneto control was connected to the throttle shaft, however the fly lead end cover can still rotate independently-is this correct?
Sorry to appear so ill informed regarding magneto operation, until purchase a few months ago I'd never even herd of a magneto !
Yes, the bakelite cap can go in any position, it is there to make contact with the centre bolt on the contact breaker assembly, when you turn off the magneto at the switch this earths the centre bolts via the sping loaded central carbon brush on the cap.
