RN and RK sunroof
(02-12-2018, 05:16 PM)Martin Prior Wrote: Ruairidh, am I right in thinking that the RN sliding roof is flat, other than a slight drop at either side?  I've been quote a depth of only 3/8" for the steel lattice panel - is that correct?
The sliding rook has a very slight curve longitudinally that follows the line of the channels it runs in, there is also a slight curve across the car and it is straight at the front.
The 3/8" depth looks correct.
It will be covered up soon so do ask anything sooner than later. I took quite a lot of photos of the degraded but original roof covering and edging which I have replicated as closely as I could.
RN and RK sunroof - by Martin Prior - 01-12-2018, 06:02 PM
RE: RN and RK sunroof - by Austin in the Shed - 01-12-2018, 07:29 PM
RE: RN and RK sunroof - by Ruairidh Dunford - 01-12-2018, 07:36 PM
RE: RN and RK sunroof - by AllAlloyCup - 01-12-2018, 08:49 PM
RE: RN and RK sunroof - by Martin Prior - 02-12-2018, 05:16 PM
RE: RN and RK sunroof - by Ruairidh Dunford - 02-12-2018, 08:44 PM
RE: RN and RK sunroof - by Martin Prior - 02-12-2018, 09:42 PM
RE: RN and RK sunroof - by Bryan Downes - 03-12-2018, 05:39 PM
RE: RN and RK sunroof - by Martin Prior - 03-12-2018, 08:00 PM
RE: RN and RK sunroof - by Ruairidh Dunford - 07-12-2018, 09:20 AM
RE: RN and RK sunroof - by Austin in the Shed - 08-12-2018, 12:58 PM
