Rad Cowl repair
(04-12-2018, 10:16 AM)atmacg Wrote:
(04-12-2018, 09:39 AM)Derek Sheldon Wrote: Was it as bad as this ?
This Rosengart radiator was dismal , splits , parts missing , poor previous repairs , you name it. You ask about splits in corners , I cut small sections of thin brass strip and fixed to the back first then silver soldered the crack up.
It is possible to use soft solder to repair areas but not recommended, the plating process becomes more complicated and more expensive. Find a good plater and talk to him.
I used, no interest in the company except a good job. Cranbourne Chrome Limited in Gosport.
Good luck
This is post plating
Thanks.Condition is not quite as bad as yours. Multiple shallow dents and ripples, The cracks are radial, about 15-20 mm long. I'll try your suggestion of backing up with silver soldered brass strip with a generous overlap then filling the front with silver solder. Heat control will be challenging. I will be painting rather than plating so the finish does not have to be perfect. Best wishes Andrew
Andrew
It would be worth talking to a model engineer... I'm fairly sure that the silver solders they use come in several grades/melting points, allowing you to join sub assemblies without everything falling apart! Heat control need not be so much of a challenge if you use the highest melting point one first.
Regards
Nick
Rad Cowl repair - by Erich - 03-10-2017, 03:06 AM
RE: Rad Cowl repair - by Charles P - 03-10-2017, 07:14 AM
RE: Rad Cowl repair - by Duncan Grimmond - 03-10-2017, 08:23 AM
RE: Rad Cowl repair - by Dave Wheatley - 03-10-2017, 09:30 AM
RE: Rad Cowl repair - by Robert Leigh - 03-10-2017, 10:22 AM
RE: Rad Cowl repair - by Duncan Grimmond - 03-10-2017, 04:23 PM
RE: Rad Cowl repair - by Erich - 03-10-2017, 05:35 PM
RE: Rad Cowl repair - by daveg - 03-10-2017, 09:16 PM
RE: Rad Cowl repair - by Duncan Grimmond - 04-10-2017, 08:53 PM
RE: Rad Cowl repair - by atmacg - 04-12-2018, 01:22 AM
RE: Rad Cowl repair - by Derek Sheldon - 04-12-2018, 09:39 AM
RE: Rad Cowl repair - by atmacg - 04-12-2018, 10:16 AM
RE: Rad Cowl repair - by Nick Lettington - 04-12-2018, 02:34 PM
RE: Rad Cowl repair - by Dave Wortley - 04-12-2018, 04:44 PM
