Con rod query
#55
(27-11-2018, 12:06 PM)Colin Wilks Wrote:  the crud that inevitably circulates in a traditional splash fed set up. As I do not want to get into fitting an oil filter I have decided to stick with white metal.
CRUD...INEVITABLY!!!!
Surely, sir, you would thoroughly clean out your engine, including crank......then good quality fully synthesised multigrade oil to keep it that way and give minimum wear........we won't mention "Merlins magic additive" (as it has once been erroneously referred to) which I would never be without in any mechanical device.
Dennis
Con rod query - by Colin Wilks - 24-11-2018, 05:35 PM
RE: Con rod query - by Tony Betts - 24-11-2018, 06:20 PM
RE: Con rod query - by Zetomagneto - 24-11-2018, 10:11 PM
RE: Con rod query - by Robert Foreman - 24-11-2018, 08:24 PM
RE: Con rod query - by Ruairidh Dunford - 24-11-2018, 08:32 PM
RE: Con rod query - by Tony Betts - 25-11-2018, 11:15 AM
RE: Con rod query - by Bob Culver - 24-11-2018, 10:47 PM
RE: Con rod query - by Zetomagneto - 24-11-2018, 10:51 PM
RE: Con rod query - by Ruairidh Dunford - 25-11-2018, 11:27 AM
RE: Con rod query - by Terrytuned - 25-11-2018, 12:52 PM
RE: Con rod query - by Zetomagneto - 25-11-2018, 09:39 PM
RE: Con rod query - by Ruairidh Dunford - 25-11-2018, 12:57 PM
RE: Con rod query - by Colin Wilks - 25-11-2018, 02:36 PM
RE: Con rod query - by Dave Wortley - 25-11-2018, 03:09 PM
RE: Con rod query - by Tony Betts - 25-11-2018, 03:31 PM
RE: Con rod query - by Chris KC - 25-11-2018, 03:17 PM
RE: Con rod query - by JonE - 25-11-2018, 04:06 PM
RE: Con rod query - by Steve Jones - 25-11-2018, 04:35 PM
RE: Con rod query - by Charles P - 25-11-2018, 05:28 PM
RE: Con rod query - by Chris KC - 25-11-2018, 05:48 PM
RE: Con rod query - by Chris KC - 25-11-2018, 03:45 PM
RE: Con rod query - by Tony Betts - 25-11-2018, 06:24 PM
RE: Con rod query - by Terrytuned - 26-11-2018, 11:31 AM
RE: Con rod query - by Colin Wilks - 26-11-2018, 11:38 AM
RE: Con rod query - by Terrytuned - 26-11-2018, 12:47 PM
RE: Con rod query - by Alan - 26-11-2018, 01:39 PM
RE: Con rod query - by Colin Wilks - 26-11-2018, 02:12 PM
RE: Con rod query - by Zetomagneto - 26-11-2018, 11:20 PM
RE: Con rod query - by Terrytuned - 26-11-2018, 07:47 PM
RE: Con rod query - by Colin Wilks - 26-11-2018, 08:05 PM
RE: Con rod query - by Stuart Giles - 26-11-2018, 09:32 PM
RE: Con rod query - by Barker - 27-11-2018, 09:09 AM
RE: Con rod query - by Colin Wilks - 27-11-2018, 12:06 PM
RE: Con rod query - by Zetomagneto - 27-11-2018, 05:58 PM
RE: Con rod query - by Steve Jones - 27-11-2018, 08:01 PM
RE: Con rod query - by Zetomagneto - 27-11-2018, 11:58 PM
RE: Con rod query - by Dennis Nicholas - 28-11-2018, 05:07 PM
RE: Con rod query - by Colin Wilks - 28-11-2018, 06:49 PM
RE: Con rod query - by JonE - 27-11-2018, 06:24 PM
RE: Con rod query - by Charles P - 27-11-2018, 06:33 PM
RE: Con rod query - by Hugh Barnes - 27-11-2018, 06:55 PM
RE: Con rod query - by Charles P - 27-11-2018, 07:19 PM
RE: Con rod query - by Hugh Barnes - 27-11-2018, 09:07 PM
RE: Con rod query - by JonE - 27-11-2018, 07:15 PM
RE: Con rod query - by Bob Culver - 27-11-2018, 07:25 PM
RE: Con rod query - by Chris KC - 27-11-2018, 11:36 PM
RE: Con rod query - by Terrytuned - 28-11-2018, 01:36 AM
RE: Con rod query - by Zetomagneto - 28-11-2018, 10:00 AM
RE: Con rod query - by Colin Reed - 28-11-2018, 09:34 AM
RE: Con rod query - by Ruairidh Dunford - 28-11-2018, 11:28 AM
RE: Con rod query - by Stuart Giles - 28-11-2018, 12:11 PM
RE: Con rod query - by Chris KC - 28-11-2018, 01:41 PM
RE: Con rod query - by Colin Wilks - 28-11-2018, 01:12 PM
RE: Con rod query - by Zetomagneto - 28-11-2018, 01:50 PM
RE: Con rod query - by Stuart Giles - 28-11-2018, 02:36 PM
RE: Con rod query - by Colin Wilks - 28-11-2018, 03:34 PM
RE: Con rod query - by Dennis Nicholas - 28-11-2018, 07:51 PM
RE: Con rod query - by Tony Press - 28-11-2018, 11:11 PM
RE: Con rod query - by Bob Culver - 28-11-2018, 08:57 PM
RE: Con rod query - by Robert Foreman - 28-11-2018, 09:43 PM
RE: Con rod query - by Colin Wilks - 28-11-2018, 10:23 PM
RE: Con rod query - by Chris KC - 28-11-2018, 10:53 PM
RE: Con rod query - by Dennis Nicholas - 29-11-2018, 02:12 AM
RE: Con rod query - by Tony Press - 29-11-2018, 02:28 AM
RE: Con rod query - by JonE - 10-05-2021, 08:46 PM
RE: Con rod query - by Robert Leigh - 10-05-2021, 09:38 PM
RE: Con rod query - by Jamie - 10-05-2021, 10:32 PM
RE: Con rod query - by Chris KC - 10-05-2021, 10:43 PM
RE: Con rod query - by Bob Culver - 11-05-2021, 12:16 AM
