27-11-2018, 04:43 PM
(This post was last modified: 27-11-2018, 05:05 PM by Geoff Halstead.)
First of the many, and I may have duplicated some.
Missed these with the NS rear inner arch repair post some time ago.
![[Image: image_zpsubs2jqcx.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Body/Inner%20Arches/NS%20Inner%20Arch/image_zpsubs2jqcx.jpeg)
![[Image: image_zps9sgbuglf.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Body/Inner%20Arches/NS%20Inner%20Arch/image_zps9sgbuglf.jpeg)
![[Image: image_zpsbkucatcm.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Body/Inner%20Arches/NS%20Inner%20Arch/image_zpsbkucatcm.jpeg)
Grinding Tappets
The valve stems had made a perfectly round indentation in them that would make it nigh on impossible to set the gaps.
Something had to be done, and not having either a surface grinder or a working toolpost grinder (I need to sort it out) I came up with the perfect Heath Robinson method.
I used my high speed drilling machine and Dremel type grinding wheel.
![[Image: image_zpsyzmoupxr.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Valve%20Tappet%20Heads/image_zpsyzmoupxr.jpeg)
After finishing on the drilling machine I finished off with a few rubs on the fine diamond abrasive.
![[Image: image_zpsu3yvqfuz.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Valve%20Tappet%20Heads/image_zpsu3yvqfuz.jpeg)
Ready to assemble to see if valve stems making even contact.
![[Image: image_zpstt4ivobr.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Valve%20Tappet%20Heads/image_zpstt4ivobr.jpeg)
Yes they do, and Heath Robinson winning the day once again.
![[Image: image_zpsfnyhvvkp.jpeg]](https://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Valve%20Tappet%20Heads/image_zpsfnyhvvkp.jpeg)
![[Image: image_zpsldcr6pfw.jpeg]](https://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Valve%20Tappet%20Heads/image_zpsldcr6pfw.jpeg)
Geoff - Bl@@dy migraine now!
REPO
(RubyEnginePartsOrganiser)
![[Image: image_zpsdokba7c1.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/REPO/image_zpsdokba7c1.jpeg)
![[Image: image_zpsqvp7jftd.jpeg]](https://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Seven%20Engine/REPO/image_zpsqvp7jftd.jpeg)
https://youtu.be/apSP8QhDpgM
Geoff - Oh YES, I can insert videos using the iPad.
Ruby engine, machining/mods
Manifold port face being machined.
Manifold Inlet being machined flat using the Boxford.
![[Image: image_zps7fdd1q1j.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Modifications/image_zps7fdd1q1j.jpeg)
![[Image: image_zpscvcbfddi.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Modifications/image_zpscvcbfddi.jpeg)
![[Image: image_zpsthqqqjwj.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Modifications/image_zpsthqqqjwj.jpeg)
Geoff - The action of the shaper is hypnotic
CylinderBlockWhatsit (CBW)
Update.
I replaced that suds cooler pipe magnet with a magnetic DTI holder that is much stronger.
![[Image: image_zpspm6ylguk.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Ruby%20Cylinder%20Block%20Stand/image_zpspm6ylguk.jpeg)
![[Image: image_zpstw139nwu.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Ruby%20Cylinder%20Block%20Stand/image_zpstw139nwu.jpeg)
Mounted on the Workbench bolted to those two lengths of square tube.
![[Image: image_zpsmhkpvgky.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Ruby%20Cylinder%20Block%20Stand/image_zpsmhkpvgky.jpeg)
![[Image: image_zpszhhqe9vb.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Ruby%20Cylinder%20Block%20Stand/image_zpszhhqe9vb.jpeg)
Enough light I hope for grinding.
![[Image: image_zpsynofjvej.jpeg]](http://i1104.photobucket.com/albums/h322/Geoff_Halstead/Austin%20Ruby/Engine/Ruby%20Cylinder%20Block%20Stand/image_zpsynofjvej.jpeg)
Geoff - That's it for a while, but if I find more, I will post,
Grinding Tappets
REPO
Update.
