Cylinder head
(21-11-2018, 02:19 PM)Malcolm Parker Wrote: I have fitted late Ruby high comp cylinder heads to several 'unknown' Austin 7 engines and in most cases the results were far from satisfactory, ie rough running, loss of power.   The reason has always been that the 14mm plugs of the late head oil up, causing the engine to run on three cylinders.
The late head is very prone to plug oiling, so unless you have an engine with good bores and piston rings, I would stick with the early head.   These are much more kind on an old unrebuilt engine and an engine running on four cylinders will always be better than one running on three.   Also kinder to the crankshaft if the engine is an unknown quantity.
If you have a nice rebuilt engine fit a later high comp head or a Ricardo aluminium head.    Best bet is to get your engine running sweetly on its low comp head and assess its overall condition.
Seems a pity not to use the later head on the grounds that it oils the plugs — I would look at fitting a Powerspark electronic ignition to your DK4A and enjoy the nice fat sparks!
Charles
Cylinder head - by Tiger - 21-11-2018, 12:22 PM
RE: Cylinder head - by Derek Sheldon - 21-11-2018, 12:28 PM
RE: Cylinder head - by JonE - 21-11-2018, 12:30 PM
RE: Cylinder head - by Chris KC - 21-11-2018, 01:20 PM
RE: Cylinder head - by Malcolm Parker - 21-11-2018, 02:19 PM
RE: Cylinder head - by Steve Jones - 21-11-2018, 02:46 PM
RE: Cylinder head - by Chris KC - 21-11-2018, 03:06 PM
RE: Cylinder head - by Charles Levien - 22-11-2018, 01:13 PM
RE: Cylinder head - by Tiger - 21-11-2018, 03:03 PM
RE: Cylinder head - by GK5268 - 21-11-2018, 03:31 PM
RE: Cylinder head - by Zetomagneto - 21-11-2018, 11:03 PM
RE: Cylinder head - by Bob Culver - 21-11-2018, 08:31 PM
RE: Cylinder head - by Alan - 21-11-2018, 08:47 PM
RE: Cylinder head - by Rogerfrench - 22-11-2018, 12:24 PM
RE: Cylinder head - by Reckless Rat - 22-11-2018, 02:22 PM
RE: Cylinder head - by Charles P - 22-11-2018, 03:43 PM
RE: Cylinder head - by Steve Jones - 22-11-2018, 05:09 PM
RE: Cylinder head - by Bill Sheehan - 23-11-2018, 12:03 AM
RE: Cylinder head - by Michael D - 23-11-2018, 08:50 AM
RE: Cylinder head - by John Cornforth - 23-11-2018, 11:21 AM
RE: Cylinder head - by Stuart Giles - 23-11-2018, 12:00 PM
RE: Cylinder head - by JonE - 23-11-2018, 01:15 PM
RE: Cylinder head - by Chris KC - 23-11-2018, 01:44 PM
RE: Cylinder head - by Stuart Giles - 23-11-2018, 04:57 PM
RE: Cylinder head - by Malcolm Parker - 24-11-2018, 12:24 PM
RE: Cylinder head - by Alan - 24-11-2018, 01:20 PM
RE: Cylinder head - by JonE - 24-11-2018, 03:35 PM
RE: Cylinder head - by Robert Leigh - 09-03-2025, 06:23 PM
RE: Cylinder head - by Tony Press - 09-03-2025, 11:05 PM
