14-11-2018, 05:55 PM
If its a special, then a standard loom may not be what you require. Have a look at a standard wiring diagram and go from there. Select the correct gauge of wire for the lamp/dynamo/ammeter etc. If you want trouble free 6volt electrics, run an earth wire to each lamp, and add an earth wire from the battery to the engine or gearbox. It sounds like you would be better off removing all the old wiring and start afresh. Once you have all your wires roughly in place, bind the 'loom' together with 'self amalgamating tape'. You can also use plastic spiral wrap, but it doesn't look quite so professional.
