New brakes binding
(10-11-2018, 12:55 AM)Tony Press Wrote:
(09-11-2018, 11:32 PM)Zetomagneto Wrote:
(09-11-2018, 10:03 PM)IGene Tony Press Wrote:
(09-11-2018, 03:20 PM)GK5268 Wrote: Check that the new drum is sitting perfectly flat on the hub, I had this issue with my new drums several years ago (part of the kit for hydraulic brake conversion), the front drums needed to have its inner radius filed where it contacts the hub (rears were fine as they had new hubs and were machined to match) and once done, fitted flat onto the hub flange.
I did not notice this at first, it wasn't until I could see that the wheel rotation was out of truth (difficulty in setting up the tracking) that I had to investigate and spotted this problem. The profile of the angle on the drum differed to that on the angle of the hub - this has a curve - the drum is square - and once they matched it was fine, it is hard to see at first, only has to be slightly out, if the drum rocks slightly before the screws are fitted, then that is your problem.
Good luck!
If I understand what you are saying- the new front hubs have a sharp corner where the flange meets the body - technically not a good thing, promoting a failure at this point ?
No, GK means the inner edge of the drums were not radiused.You certainly want a radius on the hub though, as you say
Hi Zetomagneto,
Yes- but he also said -
which seems to indicate the hub had a sharp corner ?
Tony.
To avoid any confusion, the front hubs were the originals and they are radiused between the flange and the hub projection, the rears, which were brand-new (supplied by A7 Components) are less radiused, so that the new brake drums fitted perfectly on the rear, but at the front, the edge of the central mounting hole had to be filed to suit the radius on the hub, once this was done, the drum fitted onto the flange perfectly square.
Just fitting the drums as supplied, it was not self-evident that these were out of truth, they fitted and screwed up ok, all seemed fine until I had problems setting up the tracking - the wheels were of course wobbling away - my first thought was the wheels (which had been re-built) were out of truth, but checking the drums with a dial-test indicator showed there was a run-out and then taking it all apart, the fitting of the drum onto the hub was found to be the problem as the drum was riding on the radius and not making full contact across the flange surface. Once closely inspected it was obvious what the problem was. Once the edge had been filed to suit, the drum fitted perfectly.
So, if the new drum is out of truth with the hub, not only could this affect brakes, but also the tracking and handling!
New brakes binding - by John Mims - 08-11-2018, 07:57 PM
RE: New brakes binding - by Reckless Rat - 08-11-2018, 08:20 PM
RE: New brakes binding - by John Mims - 08-11-2018, 11:11 PM
RE: New brakes binding - by Zetomagneto - 08-11-2018, 10:50 PM
RE: New brakes binding - by Tony Press - 09-11-2018, 02:10 AM
RE: New brakes binding - by John Mims - 09-11-2018, 09:13 AM
RE: New brakes binding - by Derek Sheldon - 09-11-2018, 07:52 AM
RE: New brakes binding - by Ruairidh Dunford - 09-11-2018, 10:32 AM
RE: New brakes binding - by John Mims - 09-11-2018, 11:00 AM
RE: New brakes binding - by Jamie - 09-11-2018, 10:52 AM
RE: New brakes binding - by Ruairidh Dunford - 09-11-2018, 11:20 AM
RE: New brakes binding - by Chris KC - 09-11-2018, 11:54 AM
RE: New brakes binding - by Steve Bryant - 09-11-2018, 02:35 PM
RE: New brakes binding - by GK5268 - 09-11-2018, 03:20 PM
RE: New brakes binding - by Tony Press - 09-11-2018, 10:03 PM
RE: New brakes binding - by Zetomagneto - 09-11-2018, 11:32 PM
RE: New brakes binding - by Tony Press - 10-11-2018, 12:55 AM
RE: New brakes binding - by GK5268 - 10-11-2018, 12:09 PM
RE: New brakes binding - by Steve Jones - 11-11-2018, 05:11 PM
RE: New brakes binding - by John Mims - 12-11-2018, 06:12 PM
RE: New brakes binding - by Derek Sheldon - 12-11-2018, 07:18 PM
