The symptoms of a 3 bearing crank failure?
#23
Hi KC
Your post appeared while I was still pondering.
It is not as classic as most. I am not sure where final fracture is. Usually crack starts at inside and works outward, but seems to have formed at outer diameter. Is it from an engine in normal use or high rpm?
RE: The symptoms of a 3 bearing crank failure? - by Bob Culver - 09-11-2018, 08:40 PM
