The symptoms of a 3 bearing crank failure?
Managed to get the inspection plate off the flywheel last night to give the flywheel a wiggle. It definable moves around in a way it was never intended to! It's doesn't feel like it's loose on the crank, so I'm still working the theory that the crank is indeed broken. Engine should be out tomorrow so I can understand the failure properly.
@Chris KC - useful to know new 3brg cranks are available - any idea who I may be able to source one from?
Thanks
Ray
RE: The symptoms of a 3 bearing crank failure? - by fatcatvera - 09-11-2018, 10:03 AM
