Exhaust valves
The seating area on an exhaust valve is quite hard, so the usual method of machining is with a valve grinding machine. Most companies who do re-boring crank grinding etc. will have a valve grinding machine. There needs to be enough margin (i.e. thickness) above the re-machined seat on the valve head to prevent the valve distorting in service. In other words if the seat of the valve would make a 45 degree sharp edge with the face of the valve once its machined it really needs to go in the bin.
Exhaust valves - by Tiger - 09-11-2018, 06:31 AM
RE: Exhaust valves - by bob46320 - 09-11-2018, 07:50 AM
RE: Exhaust valves - by Zetomagneto - 09-11-2018, 11:22 PM
RE: Exhaust valves - by Bob Culver - 09-11-2018, 08:02 AM
RE: Exhaust valves - by Stuart Giles - 09-11-2018, 08:57 AM
RE: Exhaust valves - by Ruairidh Dunford - 09-11-2018, 09:39 AM
RE: Exhaust valves - by Chris KC - 09-11-2018, 09:52 AM
RE: Exhaust valves - by Stuart Giles - 09-11-2018, 10:09 AM
RE: Exhaust valves - by Ruairidh Dunford - 09-11-2018, 10:24 AM
RE: Exhaust valves - by Bob Culver - 10-11-2018, 04:01 AM
RE: Exhaust valves - by Tiger - 10-11-2018, 07:46 AM
RE: Exhaust valves - by Bob Culver - 10-11-2018, 10:03 AM
RE: Exhaust valves - by Steve kay - 11-11-2018, 01:11 PM
RE: Exhaust valves - by John Mason - 11-11-2018, 02:36 PM
RE: Exhaust valves - by Ruairidh Dunford - 11-11-2018, 03:00 PM
RE: Exhaust valves - by John Mason - 11-11-2018, 04:13 PM
RE: Exhaust valves - by Jeff Taylor - 11-11-2018, 04:53 PM
