08-11-2018, 11:13 AM
Ray, Take the flywheel cover off first and you may be able to tell on jiggling the flywheel about using a screwdriver lever against the crankcase if it is a loose flywheel or a broken crank.
The symptoms of a 3 bearing crank failure?
