Smelly fumes inside car
Precise management of the battery can be a challenge. Yet Ford 8s did not even have the Summer option. I know for decades the battery life on my RP was about 2 years.....
Later on long trips I used to remove the dynamo fuse and switch to Summer, so no charge. (Will not work if car has acquired a complete 4 pole DEL dynamo).  I  fitted a voltmeter but found I could not take eyes off the road long enough to read!
A digital meter even inside the cabin may not cope with the unsuppressed spark and other noise. An analogue meter fitted with a zener to expand the scale, calibrated from a digital,  can be useful. If a dynamo off switch is fitted it should be wired to switch the fileld wire not the output.
Smelly fumes inside car - by Tattybogle - 21-09-2017, 02:50 PM
RE: Smelly fumes inside car - by Jack in the Box - 21-09-2017, 07:02 PM
RE: Smelly fumes inside car - by Tattybogle - 22-09-2017, 10:46 AM
RE: Smelly fumes inside car - by Bob Culver - 21-09-2017, 08:30 PM
RE: Smelly fumes inside car - by Andy Bennett - 21-09-2017, 08:34 PM
RE: Smelly fumes inside car - by Bob Culver - 23-09-2017, 09:47 AM
RE: Smelly fumes inside car - by Tattybogle - 24-09-2017, 12:55 PM
RE: Smelly fumes inside car - by Tony Press - 24-09-2017, 11:37 PM
RE: Smelly fumes inside car - by A G Wood - 27-09-2017, 04:27 AM
RE: Smelly fumes inside car - by Bob Culver - 24-09-2017, 08:02 PM
RE: Smelly fumes inside car - by Bob Culver - 28-09-2017, 07:04 AM
