Rear Brake Actuator Orientation
(03-11-2018, 05:24 PM)Reckless Rat Wrote: If they're both at 8 o'clock then you've got a problem on one side! Ideally the angle between the cable and the actuator lever should always be acute and not pass 90° when fully applied. Make sure that when adjusting up the front brakes come on before the rears or you'll end up facing back the way you came.
Well spotted Reckless! I should have said 8 o’clock on the off side and 4 o’clock on the near side.
Rear Brake Actuator Orientation - by Matt_Harnden - 03-11-2018, 04:50 PM
RE: Rear Brake Actuator Orientation - by Matt_Harnden - 03-11-2018, 05:38 PM
