Engine locked
(03-11-2018, 01:23 PM)Tiger Wrote: By the way 3 crank bearing engine.
Further to what John said, when tightening centre main bolts and big ends they should be done half-tight then given a good tap on the side to jog things into place before fully tightening. Failure to do this can result in binding. Also if centre main is not in line, tightening the c/m fixings can pinch the shaft.
How about the gears on the end of the camshaft and crankshaft, have these run together before?
Engine locked - by Tiger - 03-11-2018, 09:27 AM
RE: Engine locked - by Martin Prior - 03-11-2018, 09:34 AM
RE: Engine locked - by squeak - 03-11-2018, 09:38 AM
RE: Engine locked - by Ruairidh Dunford - 03-11-2018, 09:41 AM
RE: Engine locked - by John Mason - 03-11-2018, 11:06 AM
RE: Engine locked - by AllAlloyCup - 03-11-2018, 11:16 AM
RE: Engine locked - by Tiger - 03-11-2018, 11:51 AM
RE: Engine locked - by Bryan - 03-11-2018, 12:09 PM
RE: Engine locked - by Tiger - 03-11-2018, 12:21 PM
RE: Engine locked - by Ruairidh Dunford - 03-11-2018, 12:24 PM
RE: Engine locked - by Chris KC - 03-11-2018, 12:24 PM
RE: Engine locked - by John Mason - 03-11-2018, 12:44 PM
RE: Engine locked - by Tiger - 03-11-2018, 01:15 PM
RE: Engine locked - by Colin Wilks - 03-11-2018, 01:20 PM
RE: Engine locked - by Tiger - 03-11-2018, 01:23 PM
RE: Engine locked - by Chris KC - 03-11-2018, 01:44 PM
RE: Engine locked - by Ruairidh Dunford - 03-11-2018, 01:48 PM
RE: Engine locked - by Tiger - 03-11-2018, 05:16 PM
RE: Engine locked - by Chris KC - 03-11-2018, 05:40 PM
RE: Engine locked - by Tony Press - 03-11-2018, 10:08 PM
RE: Engine locked - by Tiger - 04-11-2018, 11:19 AM
