Manifold stud removal
Alan, I wouldn't use an extractor, they don't work particularly well on small holes. You will have to drill a hole in order to use it so you may as well drill tapping size for 1/4 BSF and retap it.
You could use the manifold as a drilling guide by getting some one to turn a steel tube, OD to fit the manifold stud hole, ID 1/4 BSF tapping size.bolt the manifold back on drill , not to deep, probably no more than 3/8" then tap.If you find it difficult to tap square to the face use the manifold again as a tapping guide
Manifold stud removal - by Alan Ashton - 20-09-2017, 04:56 PM
RE: Manifold stud removal - by Chris KC - 20-09-2017, 07:11 PM
RE: Manifold stud removal - by Alan - 20-09-2017, 07:17 PM
RE: Manifold stud removal - by Chris Garner - 20-09-2017, 08:01 PM
RE: Manifold stud removal - by Shuttle - 20-09-2017, 08:13 PM
RE: Manifold stud removal - by Bob Culver - 20-09-2017, 09:09 PM
RE: Manifold stud removal - by Alan - 20-09-2017, 09:27 PM
RE: Manifold stud removal - by Zetomagneto - 20-09-2017, 10:08 PM
RE: Manifold stud removal - by Alan - 20-09-2017, 10:20 PM
RE: Manifold stud removal - by Nick Salmon - 20-09-2017, 10:26 PM
RE: Manifold stud removal - by Speedex750 - 21-09-2017, 08:59 AM
RE: Manifold stud removal - by Jack in the Box - 21-09-2017, 08:34 AM
RE: Manifold stud removal - by Alan Ashton - 21-09-2017, 07:11 PM
RE: Manifold stud removal - by Tony R - 21-09-2017, 07:31 PM
RE: Manifold stud removal - by Zetomagneto - 21-09-2017, 09:53 PM
RE: Manifold stud removal - by Hugh Barnes - 22-09-2017, 09:40 AM
RE: Manifold stud removal - by Charles P - 22-09-2017, 10:15 AM
RE: Manifold stud removal - by Ruairidh Dunford - 22-09-2017, 10:35 AM
RE: Manifold stud removal - by Charles P - 22-09-2017, 11:34 PM
RE: Manifold stud removal - by Hugh Barnes - 23-09-2017, 08:46 AM
RE: Manifold stud removal - by Pricey - 22-09-2017, 08:10 PM
RE: Manifold stud removal - by Ritchie Wilson - 30-12-2018, 01:33 AM
RE: Manifold stud removal - by Ruairidh Dunford - 22-09-2017, 11:41 PM
RE: Manifold stud removal - by JonE - 29-12-2018, 11:06 PM
RE: Manifold stud removal - by Jeff Taylor - 30-12-2018, 02:53 AM
