(23-10-2018, 07:55 PM)Howard Wright Wrote: I took the speedo cable out of the RK to investigate why the speedo was so erratic.  Turns out the sheath had come unsoldered causing the cable to hardly reach the drive.
Why is worn aluminium and grease (like that found all over the speedo cable) an absolute pain to get off your hands!
Perhaps you already do Howard, but those who don't a 'top tip' is to use barrier cream on your hands before working on the car. It is of course conceived to protect your skin but has the side effect of making your hands much easier to get clean, especially if you work it under your finger nails when applying.
RE: What have you done today with your Austin Seven - by Chris KC - 23-10-2018, 08:06 PM
Users browsing this thread: 27 Guest(s)
