  • 1 Vote(s) - 3 Average
Oversize gudgeon pins
(23-10-2018, 07:37 AM)Ruairidh Dunford Wrote: Simon,
in your shoes, I would be looking to source another rod.
However if you do proceed as discussed above, remember you will need clamp type gudgeon pins.
At the moment we don’t know what rods Simon has, but yes obviously clamp type for clamp type rods but others have converted clamp type rods to fully floating by inserting an appropriate thickness of packing in the slot and boringe the hole.This was done to use The Honda pistons,we don’t need to do that now as Tony does the slipper pistons.
Simons question was where to get oversize pins, it has been answered.Simon can use 13mm pins, if he has clamp type rods he can grind,or have ground the clearance in the middle of the pin for the clamp bolt.Another rod was suggested early in the thread, clearly he does not want to do it that way.
Oversize gudgeon pins - by "Slack Alice" Simon - 16-10-2018, 05:56 PM
RE: Oversize gudgeon pins - by dickie65 - 16-10-2018, 07:27 PM
RE: Oversize gudgeon pins - by Ian Williams - 16-10-2018, 08:58 PM
RE: Oversize gudgeon pins - by Zetomagneto - 16-10-2018, 09:23 PM
RE: Oversize gudgeon pins - by Robert Foreman - 16-10-2018, 10:16 PM
RE: Oversize gudgeon pins - by Zetomagneto - 16-10-2018, 10:26 PM
RE: Oversize gudgeon pins - by Zetomagneto - 22-10-2018, 10:06 PM
RE: Oversize gudgeon pins - by Ruairidh Dunford - 23-10-2018, 07:37 AM
RE: Oversize gudgeon pins - by Zetomagneto - 23-10-2018, 08:15 AM
RE: Oversize gudgeon pins - by Ruairidh Dunford - 23-10-2018, 08:21 AM
RE: Oversize gudgeon pins - by Zetomagneto - 23-10-2018, 09:04 AM
RE: Oversize gudgeon pins - by Ruairidh Dunford - 23-10-2018, 10:40 AM
RE: Oversize gudgeon pins - by Zetomagneto - 23-10-2018, 01:28 PM
RE: Oversize gudgeon pins - by Ruairidh Dunford - 23-10-2018, 04:16 PM
RE: Oversize gudgeon pins - by Zetomagneto - 23-10-2018, 04:40 PM
RE: Oversize gudgeon pins - by Zetomagneto - 23-10-2018, 10:49 PM
