Close Ratio Gearbox
Hello Hugh,
A slight correction to Charles reply, I have an AB intermediate gear set, not an 'Andes' which as I understand it refers only to the three speed box others have mentioned in this thread.
My RP has a standard back axle and runs on 17" wheels, so relatively close to your Opal configuration. The intermediate gear set raises 1, 2, and 3rd gear leaving top as it was. I find that 1st is absolutely fine for hill starts, unless very fully loaded, when a bit more welly will be required. On the flat, two up, I can easily pull away in 2nd. Where it excels is accelerating in 3rd to an easy 35+, when changing into top the engine does not bog down. The change down from top to 3rd is at a better speed for maintaining momentum and momentum is what driving the 7 is all about.
I should add that on tour with a full set of spares, luggage and 2 up my RP has been weighed at around 950kgs, no lightweight then. Those long uphill slogs in third because a change into top would result in a loss of speed are no longer an issue, unless the hill is v.steep when 3rd is now a higher option. I think you would not regret the change.
Close Ratio Gearbox - by Hugh Barnes - 18-10-2018, 01:21 PM
RE: Close Ratio Gearbox - by Dave Wortley - 18-10-2018, 01:47 PM
RE: Close Ratio Gearbox - by Hugh Barnes - 18-10-2018, 02:37 PM
RE: Close Ratio Gearbox - by Charles Levien - 18-10-2018, 03:44 PM
RE: Close Ratio Gearbox - by Hugh Barnes - 18-10-2018, 04:03 PM
RE: Close Ratio Gearbox - by Robert Leigh - 19-10-2018, 12:29 PM
RE: Close Ratio Gearbox - by GK5268 - 18-10-2018, 05:23 PM
RE: Close Ratio Gearbox - by Dave Mann - 18-10-2018, 06:06 PM
RE: Close Ratio Gearbox - by Chris KC - 18-10-2018, 08:17 PM
RE: Close Ratio Gearbox - by AustinWood - 18-10-2018, 11:04 PM
RE: Close Ratio Gearbox - by Bob Culver - 19-10-2018, 01:08 AM
RE: Close Ratio Gearbox - by Hugh Barnes - 19-10-2018, 08:02 AM
RE: Close Ratio Gearbox - by Oxford Jack - 19-10-2018, 06:59 PM
RE: Close Ratio Gearbox - by Bob Culver - 19-10-2018, 08:05 PM
RE: Close Ratio Gearbox - by Oxford Jack - 19-10-2018, 11:42 PM
RE: Close Ratio Gearbox - by Ruairidh Dunford - 19-10-2018, 11:55 PM
RE: Close Ratio Gearbox - by Bob Culver - 20-10-2018, 09:30 AM
RE: Close Ratio Gearbox - by Hugh Barnes - 20-10-2018, 12:30 PM
RE: Close Ratio Gearbox - by Zetomagneto - 20-10-2018, 01:47 PM
RE: Close Ratio Gearbox - by Charles P - 20-10-2018, 01:58 PM
RE: Close Ratio Gearbox - by Zetomagneto - 20-10-2018, 09:09 PM
RE: Close Ratio Gearbox - by Tony Press - 21-10-2018, 01:51 AM
RE: Close Ratio Gearbox - by Colin Reed - 21-10-2018, 03:50 AM
RE: Close Ratio Gearbox - by Bob Culver - 20-10-2018, 04:37 PM
RE: Close Ratio Gearbox - by Robert Foreman - 20-10-2018, 08:40 PM
RE: Close Ratio Gearbox - by Alan - 20-10-2018, 08:46 PM
RE: Close Ratio Gearbox - by Charles P - 21-10-2018, 08:16 AM
RE: Close Ratio Gearbox - by Ian Williams - 21-10-2018, 03:58 AM
RE: Close Ratio Gearbox - by Ritchie Wilson - 21-10-2018, 08:03 AM
RE: Close Ratio Gearbox - by Hugh Barnes - 21-10-2018, 09:29 AM
RE: Close Ratio Gearbox - by Alan - 21-10-2018, 09:30 AM
RE: Close Ratio Gearbox - by Ruairidh Dunford - 21-10-2018, 09:33 AM
RE: Close Ratio Gearbox - by Andy Bennett - 22-10-2018, 07:23 AM
RE: Close Ratio Gearbox - by Ruairidh Dunford - 22-10-2018, 07:25 AM
RE: Close Ratio Gearbox - by Andy Bennett - 22-10-2018, 07:46 PM
RE: Close Ratio Gearbox - by Jeff Taylor - 22-10-2018, 11:02 PM
RE: Close Ratio Gearbox - by Ruairidh Dunford - 23-10-2018, 06:59 AM
RE: Close Ratio Gearbox - by AustinWood - 23-10-2018, 09:13 AM
RE: Close Ratio Gearbox - by Timothy P - 23-10-2018, 12:04 PM
RE: Close Ratio Gearbox - by Andy Bennett - 23-10-2018, 01:42 PM
RE: Close Ratio Gearbox - by AustinWood - 23-10-2018, 04:11 PM
