Switching from 6V to 12V, voltage regulator?!
Dear all,
greeting from Italy! I am restoring an Austin Seven special and i would like to do 12V conversion.
I would like to keep the original Dinamo, as it has been rebuilt freshly, but what about the voltage regulator should i use?
If i recall correctly, i had read somewhere about the use of an electronic "modern" voltage regulator 12V to install instead of the original
unit that should fit.
Any suggestion or "way to do it" would be greatly appreciated
Thanks to all the contributors!
Emanuel
Switching from 6V to 12V, voltage regulator?! - by borchi1 - 19-10-2018, 03:02 PM
