Oil tight Austin Seven?
I'm not going to waste my time with a detailed reply, although I can easily demonstrate that virtually everything that you say is, at best, grossly inaccurate.
Your own photos do much of the work for me, anyway.
The seller and I refused to accept your payment until you had inspected the car, which you did in the most cursory way possible.
I appear to be your scapegoat for a decision that you now regret.
Oil tight Austin Seven? - by Ruairidh Dunford - 05-10-2018, 08:11 AM
RE: Oil tight Austin Seven? - by Jamie - 05-10-2018, 08:58 AM
RE: Oil tight Austin Seven? - by morrisminor - 05-10-2018, 09:11 AM
RE: Oil tight Austin Seven? - by JonE - 05-10-2018, 09:16 AM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 09:31 AM
RE: Oil tight Austin Seven? - by Martin Prior - 05-10-2018, 10:49 AM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 08:17 PM
RE: Oil tight Austin Seven? - by Chris KC - 09-10-2018, 08:28 PM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 08:46 PM
RE: Oil tight Austin Seven? - by Duncan Logan - 10-10-2018, 07:52 AM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 10:23 AM
RE: Oil tight Austin Seven? - by Dave Mann - 05-10-2018, 10:14 AM
RE: Oil tight Austin Seven? - by Martin Prior - 05-10-2018, 10:44 AM
RE: Oil tight Austin Seven? - by Simon Scott - 05-10-2018, 10:45 AM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 10:58 AM
RE: Oil tight Austin Seven? - by Hedd_Jones - 05-10-2018, 12:19 PM
RE: Oil tight Austin Seven? - by Ian Dunford - 05-10-2018, 04:05 PM
RE: Oil tight Austin Seven? - by Austin Carr - 05-10-2018, 04:31 PM
RE: Oil tight Austin Seven? - by Hedd_Jones - 05-10-2018, 04:52 PM
RE: Oil tight Austin Seven? - by John Mason - 05-10-2018, 04:56 PM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 05:21 PM
RE: Oil tight Austin Seven? - by Dave Mann - 05-10-2018, 05:42 PM
RE: Oil tight Austin Seven? - by spannerman - 05-10-2018, 05:54 PM
RE: Oil tight Austin Seven? - by Ian Williams - 05-10-2018, 08:46 PM
RE: Oil tight Austin Seven? - by Bob Culver - 06-10-2018, 07:58 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 06-10-2018, 08:38 AM
RE: Oil tight Austin Seven? - by Mark McKibbin - 08-10-2018, 11:49 AM
RE: Oil tight Austin Seven? - by Dave Mann - 06-10-2018, 09:29 AM
RE: Oil tight Austin Seven? - by Chris KC - 06-10-2018, 10:21 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 06-10-2018, 11:04 AM
RE: Oil tight Austin Seven? - by Dave Mann - 07-10-2018, 08:57 AM
RE: Oil tight Austin Seven? - by Chris KC - 07-10-2018, 02:43 PM
RE: Oil tight Austin Seven? - by Colin Morgan - 07-10-2018, 10:36 AM
RE: Oil tight Austin Seven? - by Dave Mann - 07-10-2018, 02:51 PM
RE: Oil tight Austin Seven? - by Colin Wilks - 07-10-2018, 04:20 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 08-10-2018, 12:30 PM
RE: Oil tight Austin Seven? - by Martin Prior - 09-10-2018, 09:31 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 08-10-2018, 02:13 PM
RE: Oil tight Austin Seven? - by JonE - 09-10-2018, 10:08 AM
RE: Oil tight Austin Seven? - by Zetomagneto - 09-10-2018, 09:25 PM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 03:31 PM
RE: Oil tight Austin Seven? - by Martin Prior - 09-10-2018, 03:56 PM
RE: Oil tight Austin Seven? - by JonE - 09-10-2018, 03:57 PM
RE: Oil tight Austin Seven? - by Ian Williams - 09-10-2018, 08:09 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 09-10-2018, 09:43 PM
RE: Oil tight Austin Seven? - by Tony Press - 10-10-2018, 05:29 AM
RE: Oil tight Austin Seven? - by JonE - 10-10-2018, 11:08 AM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 11:37 AM
RE: Oil tight Austin Seven? - by Biddlecombe - 10-10-2018, 11:35 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 10-10-2018, 03:09 PM
RE: Oil tight Austin Seven? - by John Mason - 10-10-2018, 04:25 PM
RE: Oil tight Austin Seven? - by jansens - 10-10-2018, 07:45 PM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 08:04 PM
RE: Oil tight Austin Seven? - by Tony Press - 11-10-2018, 01:38 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 07:06 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 07:44 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:08 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 08:25 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 08:27 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:38 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 08:42 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 09:28 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:54 AM
RE: Oil tight Austin Seven? - by stuartu - 11-10-2018, 08:55 AM
RE: Oil tight Austin Seven? - by Dave Mann - 11-10-2018, 09:56 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:11 AM
RE: Oil tight Austin Seven? - by Terry McGrath - 11-10-2018, 10:13 AM
RE: Oil tight Austin Seven? - by squeak - 11-10-2018, 12:27 PM
RE: Oil tight Austin Seven? - by Annaustin - 13-10-2018, 11:05 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:12 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:18 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:36 AM
RE: Oil tight Austin Seven? - by Tony Press - 11-10-2018, 10:57 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:39 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:51 AM
RE: Oil tight Austin Seven? - by Hedd_Jones - 11-10-2018, 10:07 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 02:43 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 12-10-2018, 08:26 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 12-10-2018, 10:34 PM
RE: Oil tight Austin Seven? - by squeak - 13-10-2018, 02:39 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 13-10-2018, 09:02 AM
RE: Oil tight Austin Seven? - by DazeOff - 14-10-2018, 07:19 PM
RE: Oil tight Austin Seven? - by JonE - 13-10-2018, 03:59 PM
RE: Oil tight Austin Seven? - by Tony Press - 13-10-2018, 09:49 PM
RE: Oil tight Austin Seven? - by Duncan Logan - 15-10-2018, 05:46 AM
RE: Oil tight Austin Seven? - by squeak - 13-10-2018, 11:15 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 14-10-2018, 08:22 PM
RE: Oil tight Austin Seven? - by Tony Press - 14-10-2018, 10:19 PM
RE: Oil tight Austin Seven? - by Ian Williams - 14-10-2018, 08:27 PM
RE: Oil tight Austin Seven? - by Viteran - 14-10-2018, 10:46 PM
RE: Oil tight Austin Seven? - by Bob Culver - 15-10-2018, 07:16 AM
RE: Oil tight Austin Seven? - by Ian Williams - 15-10-2018, 09:40 AM
RE: Oil tight Austin Seven? - by merlinart - 15-10-2018, 02:14 PM
RE: Oil tight Austin Seven? - by Tony Press - 15-10-2018, 10:06 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 15-10-2018, 09:45 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 15-10-2018, 11:43 AM
RE: Oil tight Austin Seven? - by Martin Prior - 15-10-2018, 12:16 PM
RE: Oil tight Austin Seven? - by Ray White - 15-10-2018, 02:05 PM
RE: Oil tight Austin Seven? - by vintage_racing - 16-10-2018, 10:02 AM
RE: Oil tight Austin Seven? - by Dave Prior - 16-10-2018, 10:15 AM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 10:32 AM
RE: Oil tight Austin Seven? - by DazeOff - 16-10-2018, 08:10 PM
RE: Oil tight Austin Seven? - by Ray White - 16-10-2018, 11:48 AM
RE: Oil tight Austin Seven? - by John Mason - 16-10-2018, 12:29 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 16-10-2018, 12:56 PM
RE: Oil tight Austin Seven? - by DazeOff - 16-10-2018, 07:27 PM
RE: Oil tight Austin Seven? - by Ian Williams - 16-10-2018, 08:10 PM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 08:40 PM
RE: Oil tight Austin Seven? - by Ray White - 16-10-2018, 08:50 PM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 09:24 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 16-10-2018, 09:37 PM
RE: Oil tight Austin Seven? - by Zetomagneto - 16-10-2018, 10:06 PM
RE: Oil tight Austin Seven? - by Tony Press - 16-10-2018, 11:57 PM
