Help/Advice required...Will only run on full choke, produces white smoke
Wrapping a wet cloth tightly around the carb to manifold joint will temporarily seal an induction leak and saves you having to remove the carb to check.
If you have access to a compressor you may wish to consider buying a Leak Down Tester - this tool allows you to check individual cylinders for leaks and will also allow you to quickly determine if they being caused by inlet/exhaust valve, rings or gasket. A very useful and relatively inexpensive diagnostic tool.
RE: Help/Advice required...Will only run on full choke, produces white smoke - by Ruairidh Dunford - 18-09-2017, 08:21 PM
