Oil tight Austin Seven?
#78
(11-10-2018, 09:36 AM)jansens Wrote: I mean the idea of using plugged in EVs as short term storage. Same idea on a smaller but more distributed scale. I was never sure how consumers would take to the idea though, telling them you plug your car in to charge but sometimes we'll take power back out of it! And I am sure the power companies would find a way to charge you for both directions.
That's cool how the turbines at Cruachan work both ways around, as generators and as pumps.
In Victoria and New South Wales we are starting to build a pumped storage (better late than never? )
South Australia has a big battery (only one !)
Electric Cars are not a proposition, at least not with primarily coal fired power .
Alternative fuels?
Oil tight Austin Seven? - by Ruairidh Dunford - 05-10-2018, 08:11 AM
RE: Oil tight Austin Seven? - by Jamie - 05-10-2018, 08:58 AM
RE: Oil tight Austin Seven? - by morrisminor - 05-10-2018, 09:11 AM
RE: Oil tight Austin Seven? - by JonE - 05-10-2018, 09:16 AM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 09:31 AM
RE: Oil tight Austin Seven? - by Martin Prior - 05-10-2018, 10:49 AM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 08:17 PM
RE: Oil tight Austin Seven? - by Chris KC - 09-10-2018, 08:28 PM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 08:46 PM
RE: Oil tight Austin Seven? - by Duncan Logan - 10-10-2018, 07:52 AM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 10:23 AM
RE: Oil tight Austin Seven? - by Dave Mann - 05-10-2018, 10:14 AM
RE: Oil tight Austin Seven? - by Martin Prior - 05-10-2018, 10:44 AM
RE: Oil tight Austin Seven? - by Simon Scott - 05-10-2018, 10:45 AM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 10:58 AM
RE: Oil tight Austin Seven? - by Hedd_Jones - 05-10-2018, 12:19 PM
RE: Oil tight Austin Seven? - by Ian Dunford - 05-10-2018, 04:05 PM
RE: Oil tight Austin Seven? - by Austin Carr - 05-10-2018, 04:31 PM
RE: Oil tight Austin Seven? - by Hedd_Jones - 05-10-2018, 04:52 PM
RE: Oil tight Austin Seven? - by John Mason - 05-10-2018, 04:56 PM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 05:21 PM
RE: Oil tight Austin Seven? - by Dave Mann - 05-10-2018, 05:42 PM
RE: Oil tight Austin Seven? - by spannerman - 05-10-2018, 05:54 PM
RE: Oil tight Austin Seven? - by Ian Williams - 05-10-2018, 08:46 PM
RE: Oil tight Austin Seven? - by Bob Culver - 06-10-2018, 07:58 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 06-10-2018, 08:38 AM
RE: Oil tight Austin Seven? - by Mark McKibbin - 08-10-2018, 11:49 AM
RE: Oil tight Austin Seven? - by Dave Mann - 06-10-2018, 09:29 AM
RE: Oil tight Austin Seven? - by Chris KC - 06-10-2018, 10:21 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 06-10-2018, 11:04 AM
RE: Oil tight Austin Seven? - by Dave Mann - 07-10-2018, 08:57 AM
RE: Oil tight Austin Seven? - by Chris KC - 07-10-2018, 02:43 PM
RE: Oil tight Austin Seven? - by Colin Morgan - 07-10-2018, 10:36 AM
RE: Oil tight Austin Seven? - by Dave Mann - 07-10-2018, 02:51 PM
RE: Oil tight Austin Seven? - by Colin Wilks - 07-10-2018, 04:20 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 08-10-2018, 12:30 PM
RE: Oil tight Austin Seven? - by Martin Prior - 09-10-2018, 09:31 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 08-10-2018, 02:13 PM
RE: Oil tight Austin Seven? - by JonE - 09-10-2018, 10:08 AM
RE: Oil tight Austin Seven? - by Zetomagneto - 09-10-2018, 09:25 PM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 03:31 PM
RE: Oil tight Austin Seven? - by Martin Prior - 09-10-2018, 03:56 PM
RE: Oil tight Austin Seven? - by JonE - 09-10-2018, 03:57 PM
RE: Oil tight Austin Seven? - by Ian Williams - 09-10-2018, 08:09 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 09-10-2018, 09:43 PM
RE: Oil tight Austin Seven? - by Tony Press - 10-10-2018, 05:29 AM
RE: Oil tight Austin Seven? - by JonE - 10-10-2018, 11:08 AM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 11:37 AM
RE: Oil tight Austin Seven? - by Biddlecombe - 10-10-2018, 11:35 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 10-10-2018, 03:09 PM
RE: Oil tight Austin Seven? - by John Mason - 10-10-2018, 04:25 PM
RE: Oil tight Austin Seven? - by jansens - 10-10-2018, 07:45 PM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 08:04 PM
RE: Oil tight Austin Seven? - by Tony Press - 11-10-2018, 01:38 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 07:06 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 07:44 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:08 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 08:25 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 08:27 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:38 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 08:42 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 09:28 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:54 AM
RE: Oil tight Austin Seven? - by stuartu - 11-10-2018, 08:55 AM
RE: Oil tight Austin Seven? - by Dave Mann - 11-10-2018, 09:56 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:11 AM
RE: Oil tight Austin Seven? - by Terry McGrath - 11-10-2018, 10:13 AM
RE: Oil tight Austin Seven? - by squeak - 11-10-2018, 12:27 PM
RE: Oil tight Austin Seven? - by Annaustin - 13-10-2018, 11:05 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:12 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:18 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:36 AM
RE: Oil tight Austin Seven? - by Tony Press - 11-10-2018, 10:57 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:39 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:51 AM
RE: Oil tight Austin Seven? - by Hedd_Jones - 11-10-2018, 10:07 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 02:43 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 12-10-2018, 08:26 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 12-10-2018, 10:34 PM
RE: Oil tight Austin Seven? - by squeak - 13-10-2018, 02:39 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 13-10-2018, 09:02 AM
RE: Oil tight Austin Seven? - by DazeOff - 14-10-2018, 07:19 PM
RE: Oil tight Austin Seven? - by JonE - 13-10-2018, 03:59 PM
RE: Oil tight Austin Seven? - by Tony Press - 13-10-2018, 09:49 PM
RE: Oil tight Austin Seven? - by Duncan Logan - 15-10-2018, 05:46 AM
RE: Oil tight Austin Seven? - by squeak - 13-10-2018, 11:15 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 14-10-2018, 08:22 PM
RE: Oil tight Austin Seven? - by Tony Press - 14-10-2018, 10:19 PM
RE: Oil tight Austin Seven? - by Ian Williams - 14-10-2018, 08:27 PM
RE: Oil tight Austin Seven? - by Viteran - 14-10-2018, 10:46 PM
RE: Oil tight Austin Seven? - by Bob Culver - 15-10-2018, 07:16 AM
RE: Oil tight Austin Seven? - by Ian Williams - 15-10-2018, 09:40 AM
RE: Oil tight Austin Seven? - by merlinart - 15-10-2018, 02:14 PM
RE: Oil tight Austin Seven? - by Tony Press - 15-10-2018, 10:06 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 15-10-2018, 09:45 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 15-10-2018, 11:43 AM
RE: Oil tight Austin Seven? - by Martin Prior - 15-10-2018, 12:16 PM
RE: Oil tight Austin Seven? - by Ray White - 15-10-2018, 02:05 PM
RE: Oil tight Austin Seven? - by vintage_racing - 16-10-2018, 10:02 AM
RE: Oil tight Austin Seven? - by Dave Prior - 16-10-2018, 10:15 AM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 10:32 AM
RE: Oil tight Austin Seven? - by DazeOff - 16-10-2018, 08:10 PM
RE: Oil tight Austin Seven? - by Ray White - 16-10-2018, 11:48 AM
RE: Oil tight Austin Seven? - by John Mason - 16-10-2018, 12:29 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 16-10-2018, 12:56 PM
RE: Oil tight Austin Seven? - by DazeOff - 16-10-2018, 07:27 PM
RE: Oil tight Austin Seven? - by Ian Williams - 16-10-2018, 08:10 PM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 08:40 PM
RE: Oil tight Austin Seven? - by Ray White - 16-10-2018, 08:50 PM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 09:24 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 16-10-2018, 09:37 PM
RE: Oil tight Austin Seven? - by Zetomagneto - 16-10-2018, 10:06 PM
RE: Oil tight Austin Seven? - by Tony Press - 16-10-2018, 11:57 PM
