05-10-2018, 05:46 PM
I have a shallow aluminium sump on my car. I gave up with the tin ones as all mine had, or quickly developed, pin holes. The aluminium ones seal with no problems and also improve the rigidity of the crankcase.
I don't use a gasket but stick it on with ThreeBond 1184. This holds very tightly and further improves the rigidity.
I use ThreeBond 1184, again with no gasket, for the block to crankcase. I am of the opinion that having as rigid a joint here as possible reduces the chance of the block coming loose. Even a very small movement on the joint increases the forces on the studs dramatically.
A friend was helping Chris Gould's 10000 mile record attempt and told me about the block being held down with a brake cable.
