Hole in piston
#29
The plot thickens. Still difficult to know what started generation of all the heat in the first place. Possibly a part seizure which has persisted long enough generate a lot of heat and  to overload the big end.  I wonder if the engine had been recently rebuilt tight or piston walls built out with corrosion? Is the piston the less foregiving solid skirt type?
Whether the big end or piston seized first, the conrod has had a severe working.
Not relevant, but are the top rings different thickness'?
Hole in piston - by Colin Cheesman - 30-09-2018, 11:12 AM
RE: Hole in piston - by Chris KC - 30-09-2018, 12:36 PM
RE: Hole in piston - by Charles Levien - 30-09-2018, 05:13 PM
RE: Hole in piston - by Bob Culver - 30-09-2018, 07:48 PM
RE: Hole in piston - by Colin Reed - 30-09-2018, 08:08 PM
RE: Hole in piston - by Ian Williams - 30-09-2018, 08:22 PM
RE: Hole in piston - by Colin Cheesman - 30-09-2018, 09:51 PM
RE: Hole in piston - by Colin Cheesman - 01-10-2018, 02:59 AM
RE: Hole in piston - by Tony Press - 03-10-2018, 11:23 PM
RE: Hole in piston - by Ian Williams - 01-10-2018, 05:05 AM
RE: Hole in piston - by Colin Cheesman - 01-10-2018, 05:36 AM
RE: Hole in piston - by Ian Williams - 01-10-2018, 06:36 AM
RE: Hole in piston - by Chris KC - 01-10-2018, 10:07 AM
RE: Hole in piston - by Ian McGowan - 01-10-2018, 10:15 AM
RE: Hole in piston - by Ian Williams - 02-10-2018, 04:28 AM
RE: Hole in piston - by Ruairidh Dunford - 02-10-2018, 08:10 AM
RE: Hole in piston - by Alan - 02-10-2018, 09:34 AM
RE: Hole in piston - by Chris KC - 02-10-2018, 12:16 PM
RE: Hole in piston - by Mark Dymond - 02-10-2018, 10:35 AM
RE: Hole in piston - by Alan - 02-10-2018, 12:30 PM
RE: Hole in piston - by Colin Cheesman - 03-10-2018, 05:59 AM
RE: Hole in piston - by Ruairidh Dunford - 03-10-2018, 07:42 AM
RE: Hole in piston - by Bob Culver - 03-10-2018, 08:21 AM
RE: Hole in piston - by Chris KC - 03-10-2018, 08:47 AM
RE: Hole in piston - by Phil Kingdom - 03-10-2018, 03:05 PM
RE: Hole in piston - by Alan - 03-10-2018, 07:24 PM
RE: Hole in piston - by Ruairidh Dunford - 04-10-2018, 08:25 AM
RE: Hole in piston - by Tony Press - 04-10-2018, 11:47 PM
RE: Hole in piston - by Colin Cheesman - 04-10-2018, 09:55 AM
RE: Hole in piston - by Bob Culver - 04-10-2018, 02:02 PM
RE: Hole in piston - by Chris KC - 04-10-2018, 05:21 PM
RE: Hole in piston - by Ruairidh Dunford - 05-10-2018, 06:13 AM
RE: Hole in piston - by jansens - 05-10-2018, 06:57 AM
