REPLACING WHEEL STUD
(17-09-2017, 07:44 AM)Bob Culver Wrote: You will likely get a better response with the two problems separated. Many mechanical types are allergic to dynamos and charging systems, esp Seven ones!
There have been extensive posts on both topics.
With the hub what exactly is the problem? Do you possess a Seven puller and does it, or can one  thread fully on? Wil the taper not budge? Or is the bearing retaining nut inside the hub the challenge?
no puller and the nut has moved slighty inside
REPLACING WHEEL STUD - by david guest - 16-09-2017, 11:24 PM
RE: REPLACING WHEEL STUD - by Bob Culver - 17-09-2017, 07:44 AM
RE: REPLACING WHEEL STUD - by david guest - 17-09-2017, 09:02 AM
RE: REPLACING WHEEL STUD - by NBS - 17-09-2017, 08:01 AM
RE: REPLACING WHEEL STUD - by Ruairidh Dunford - 17-09-2017, 09:11 AM
RE: REPLACING WHEEL STUD - by david guest - 18-09-2017, 09:37 PM
