Hole in piston
#24
A most unlikely theory on the subject, but you never know stranger things have happened, having read this post it occured to me, that with a cast iron manifold and aluminium pistons you have the recipe for thermite. If a bit of rust from the manifold came into contact with a bit of aluminium oxide on the piston top, this would need a temperature of some 1650 C to ignite it, that is only a fraction of the 2500 C in a combustion chamber and it would produce a reaction of 4000 c that would easily melt a hole in a piston.
Hole in piston - by Colin Cheesman - 30-09-2018, 11:12 AM
RE: Hole in piston - by Chris KC - 30-09-2018, 12:36 PM
RE: Hole in piston - by Charles Levien - 30-09-2018, 05:13 PM
RE: Hole in piston - by Bob Culver - 30-09-2018, 07:48 PM
RE: Hole in piston - by Colin Reed - 30-09-2018, 08:08 PM
RE: Hole in piston - by Ian Williams - 30-09-2018, 08:22 PM
RE: Hole in piston - by Colin Cheesman - 30-09-2018, 09:51 PM
RE: Hole in piston - by Colin Cheesman - 01-10-2018, 02:59 AM
RE: Hole in piston - by Tony Press - 03-10-2018, 11:23 PM
RE: Hole in piston - by Ian Williams - 01-10-2018, 05:05 AM
RE: Hole in piston - by Colin Cheesman - 01-10-2018, 05:36 AM
RE: Hole in piston - by Ian Williams - 01-10-2018, 06:36 AM
RE: Hole in piston - by Chris KC - 01-10-2018, 10:07 AM
RE: Hole in piston - by Ian McGowan - 01-10-2018, 10:15 AM
RE: Hole in piston - by Ian Williams - 02-10-2018, 04:28 AM
RE: Hole in piston - by Ruairidh Dunford - 02-10-2018, 08:10 AM
RE: Hole in piston - by Alan - 02-10-2018, 09:34 AM
RE: Hole in piston - by Chris KC - 02-10-2018, 12:16 PM
RE: Hole in piston - by Mark Dymond - 02-10-2018, 10:35 AM
RE: Hole in piston - by Alan - 02-10-2018, 12:30 PM
RE: Hole in piston - by Colin Cheesman - 03-10-2018, 05:59 AM
RE: Hole in piston - by Ruairidh Dunford - 03-10-2018, 07:42 AM
RE: Hole in piston - by Bob Culver - 03-10-2018, 08:21 AM
RE: Hole in piston - by Chris KC - 03-10-2018, 08:47 AM
RE: Hole in piston - by Phil Kingdom - 03-10-2018, 03:05 PM
RE: Hole in piston - by Alan - 03-10-2018, 07:24 PM
RE: Hole in piston - by Ruairidh Dunford - 04-10-2018, 08:25 AM
RE: Hole in piston - by Tony Press - 04-10-2018, 11:47 PM
RE: Hole in piston - by Colin Cheesman - 04-10-2018, 09:55 AM
RE: Hole in piston - by Bob Culver - 04-10-2018, 02:02 PM
RE: Hole in piston - by Chris KC - 04-10-2018, 05:21 PM
RE: Hole in piston - by Ruairidh Dunford - 05-10-2018, 06:13 AM
RE: Hole in piston - by jansens - 05-10-2018, 06:57 AM
