Testing Battery Charger / Battery
My charger is an intelligent one and yes if the battery is fully discharged I it does'nt work. However it does have a battery reviver if the plates are not to badly sulphated. Check your charger instructions. You could also charge your battery a little with an old fashioned charger then change to the smart one to continue charging until it it shows with luck a full charge. Not trying to teach grandma to suck eggs but don't forget to check the electrolyte level and leave the battery cells ventilated if the battery allows this.
John Mason
Testing Battery Charger / Battery - by John P - 02-10-2018, 05:08 PM
RE: Testing Battery Charger / Battery - by John Mason - 02-10-2018, 05:43 PM
RE: Testing Battery Charger / Battery - by John P - 04-10-2018, 11:12 PM
