  • 1 Vote(s) - 4 Average
working out compression ratios
I hadn't fully appreciated the effect of the boring process and oversize pistons. Having worked out the LC head (an early one with priming brass bolts) I get about 5.2, (its like filling up a swimming pool by comparison!) which I suppose is the effect of the larger +040 cylinder being compressed into the same size head.
Btw, how are LC water outlet repair doobries affixed to the head, assuming they create a whole new mating surface? If I have a little cavity in the original mating face on the iron head, can I just fix it with JBweld or will it not last?
working out compression ratios - by JonE - 29-09-2018, 02:20 PM
RE: working out compression ratios - by Chris KC - 29-09-2018, 03:35 PM
RE: working out compression ratios - by JonE - 29-09-2018, 06:28 PM
RE: working out compression ratios - by jansens - 29-09-2018, 10:43 PM
RE: working out compression ratios - by jansens - 30-09-2018, 07:12 AM
RE: working out compression ratios - by JonE - 08-10-2018, 08:28 PM
RE: working out compression ratios - by jansens - 30-09-2018, 11:14 AM
RE: working out compression ratios - by JonE - 30-09-2018, 12:34 PM
RE: working out compression ratios - by jansens - 30-09-2018, 08:57 PM
RE: working out compression ratios - by JonE - 01-10-2018, 08:59 PM
RE: working out compression ratios - by GK5268 - 08-10-2018, 10:00 PM
RE: working out compression ratios - by JonE - 09-10-2018, 09:39 AM
RE: working out compression ratios - by JonE - 10-10-2018, 08:53 PM
RE: working out compression ratios - by JonE - 12-10-2018, 11:04 AM
RE: working out compression ratios - by JonE - 11-10-2018, 07:36 AM
RE: working out compression ratios - by jansens - 11-10-2018, 08:14 AM
RE: working out compression ratios - by JonE - 11-10-2018, 10:00 AM
RE: working out compression ratios - by jansens - 11-10-2018, 10:17 AM
RE: working out compression ratios - by Dave Mann - 11-10-2018, 10:23 AM
RE: working out compression ratios - by Dave Mann - 11-10-2018, 08:30 PM
