New to Austin Seven
Hi Simon
thanks for the reply, yes she does sit on 19'' wheels.
Since the photo was taken I've removed some crude homemade springs (like old pram springs) that were attacked to the rear axle and chassis, effectively pulling the body down.
I'm still worried about clearance, only time will tell.
The battery I plan to refit to the rear as it does sit under the car at present, the exhausts not a problem as it runs outside the car on the n/s.
Now I,ve check the car over the first major job is to rewire, hopefully it should be on the road properly in the spring.
Many thanks
Paul
New to Austin Seven - by Paul Nott - 30-09-2018, 11:47 AM
RE: New to Austin Seven - by "Slack Alice" Simon - 30-09-2018, 02:10 PM
RE: New to Austin Seven - by Paul Nott - 01-10-2018, 11:11 AM
RE: New to Austin Seven - by David.H - 01-10-2018, 11:21 AM
RE: New to Austin Seven - by "Slack Alice" Simon - 01-10-2018, 11:53 AM
RE: New to Austin Seven - by Reckless Rat - 01-10-2018, 01:24 PM
RE: New to Austin Seven - by "Slack Alice" Simon - 01-10-2018, 02:35 PM
RE: New to Austin Seven - by Paul Nott - 01-10-2018, 06:30 PM
RE: New to Austin Seven - by Peter Clayton - 13-11-2018, 11:12 PM
RE: New to Austin Seven - by Paul Nott - 14-11-2018, 04:09 PM
RE: New to Austin Seven - by Reckless Rat - 01-10-2018, 07:00 PM
RE: New to Austin Seven - by Ian Williams - 01-10-2018, 08:58 PM
RE: New to Austin Seven - by Dave Wortley - 14-11-2018, 10:25 AM
RE: New to Austin Seven - by Ian Dunford - 14-11-2018, 03:35 PM
