  • 1 Vote(s) - 4 Average
working out compression ratios
Thanks Colin and Mark for checking it for me, I had a feeling something was off. I've fixed the mistakes and re-uploaded the correct file. Mine might need lowering a bit if I blow the engine but I have the spacer plate that can go under the block when I do that.
Simon
working out compression ratios - by JonE - 29-09-2018, 02:20 PM
RE: working out compression ratios - by Chris KC - 29-09-2018, 03:35 PM
RE: working out compression ratios - by JonE - 29-09-2018, 06:28 PM
RE: working out compression ratios - by jansens - 29-09-2018, 10:43 PM
RE: working out compression ratios - by jansens - 30-09-2018, 07:12 AM
RE: working out compression ratios - by JonE - 08-10-2018, 08:28 PM
RE: working out compression ratios - by jansens - 30-09-2018, 11:14 AM
RE: working out compression ratios - by JonE - 30-09-2018, 12:34 PM
RE: working out compression ratios - by jansens - 30-09-2018, 08:57 PM
RE: working out compression ratios - by JonE - 01-10-2018, 08:59 PM
RE: working out compression ratios - by GK5268 - 08-10-2018, 10:00 PM
RE: working out compression ratios - by JonE - 09-10-2018, 09:39 AM
RE: working out compression ratios - by JonE - 10-10-2018, 08:53 PM
RE: working out compression ratios - by JonE - 12-10-2018, 11:04 AM
RE: working out compression ratios - by JonE - 11-10-2018, 07:36 AM
RE: working out compression ratios - by jansens - 11-10-2018, 08:14 AM
RE: working out compression ratios - by JonE - 11-10-2018, 10:00 AM
RE: working out compression ratios - by jansens - 11-10-2018, 10:17 AM
RE: working out compression ratios - by Dave Mann - 11-10-2018, 10:23 AM
RE: working out compression ratios - by Dave Mann - 11-10-2018, 08:30 PM
