  • 1 Vote(s) - 4 Average
working out compression ratios
Simon, I tried to validate (and simplify) your spreadsheet but I cant get what you are doing in "Clearance Volume"? have you missed a PI out of this or am I missing something?
Edit:
Attached is my attempt, with values from your spreadsheet - final value is quite different to yours I think you made an error in the way you calculate the ratio at the last step. Hope this helps
.xlsx   Compression ratio calculator_MD.xlsx (Size: 15.03 KB / Downloads: 24)
working out compression ratios - by JonE - 29-09-2018, 02:20 PM
RE: working out compression ratios - by Chris KC - 29-09-2018, 03:35 PM
RE: working out compression ratios - by JonE - 29-09-2018, 06:28 PM
RE: working out compression ratios - by jansens - 29-09-2018, 10:43 PM
RE: working out compression ratios - by jansens - 30-09-2018, 07:12 AM
RE: working out compression ratios - by JonE - 08-10-2018, 08:28 PM
RE: working out compression ratios - by Mark Dymond - 30-09-2018, 09:16 AM
RE: working out compression ratios - by jansens - 30-09-2018, 11:14 AM
RE: working out compression ratios - by JonE - 30-09-2018, 12:34 PM
RE: working out compression ratios - by jansens - 30-09-2018, 08:57 PM
RE: working out compression ratios - by JonE - 01-10-2018, 08:59 PM
RE: working out compression ratios - by GK5268 - 08-10-2018, 10:00 PM
RE: working out compression ratios - by JonE - 09-10-2018, 09:39 AM
RE: working out compression ratios - by JonE - 10-10-2018, 08:53 PM
RE: working out compression ratios - by JonE - 12-10-2018, 11:04 AM
RE: working out compression ratios - by JonE - 11-10-2018, 07:36 AM
RE: working out compression ratios - by jansens - 11-10-2018, 08:14 AM
RE: working out compression ratios - by JonE - 11-10-2018, 10:00 AM
RE: working out compression ratios - by jansens - 11-10-2018, 10:17 AM
RE: working out compression ratios - by Dave Mann - 11-10-2018, 10:23 AM
RE: working out compression ratios - by Dave Mann - 11-10-2018, 08:30 PM
