29-09-2018, 04:09 PM
I started rewiring to fit my dynamator.
After scratching my head and looking at different wiring diagrams online it turns out I have an ignition switch that was pictured in a big seven diagram. It does not have F1 or F2. (The function for adjusting charge rate is not available... it is just a key ignition switch and light switch)
Therefore the circuit is a bit simpler. I will draw a picture of it when the car is running again and charging tested.
