"cylinder head removal kit"
#23
worth mentioning, if you are making up the puller things from sparkplugs.... if you are using modern plugs then getting the ceramic out is a pain, but seems to be best via masonry drill/ cracking them out from the cylinder head chamber end first! I sheared the tops off first with anglegrinder but they are very persistent.
I've also made a step in the side with an angle grinder, as you can't do the "Ruairidh lever trick" with modern 18mm plugs as there isn't anything to wedge the lever under.
"cylinder head removal kit" - by JonE - 17-09-2018, 09:43 PM
RE: "cylinder head removal kit" - by Chris KC - 17-09-2018, 09:50 PM
RE: "cylinder head removal kit" - by Hedd_Jones - 17-09-2018, 10:02 PM
RE: "cylinder head removal kit" - by Phil Kingdom - 17-09-2018, 10:10 PM
RE: "cylinder head removal kit" - by JonE - 17-09-2018, 10:17 PM
RE: "cylinder head removal kit" - by Hedd_Jones - 17-09-2018, 11:00 PM
RE: "cylinder head removal kit" - by Phil Kingdom - 17-09-2018, 11:12 PM
RE: "cylinder head removal kit" - by Colin Morgan - 17-09-2018, 11:16 PM
RE: "cylinder head removal kit" - by Ray White - 17-09-2018, 11:27 PM
RE: "cylinder head removal kit" - by Charles P - 18-09-2018, 12:09 AM
RE: "cylinder head removal kit" - by Andy Bennett - 18-09-2018, 06:40 AM
RE: "cylinder head removal kit" - by JonE - 18-09-2018, 08:45 AM
RE: "cylinder head removal kit" - by Dave Mann - 18-09-2018, 09:03 AM
RE: "cylinder head removal kit" - by JonE - 18-09-2018, 09:56 AM
RE: "cylinder head removal kit" - by Dave Mann - 19-09-2018, 08:28 PM
RE: "cylinder head removal kit" - by JonE - 19-09-2018, 06:17 PM
RE: "cylinder head removal kit" - by Colin Wilks - 19-09-2018, 08:13 PM
RE: "cylinder head removal kit" - by JonE - 29-09-2018, 04:02 PM
RE: "cylinder head removal kit" - by JonE - 30-09-2018, 03:51 PM
RE: "cylinder head removal kit" - by Chris KC - 30-09-2018, 05:39 PM
RE: "cylinder head removal kit" - by JonE - 22-03-2019, 07:32 PM
RE: "cylinder head removal kit" - by jansens - 22-03-2019, 07:45 PM
RE: "cylinder head removal kit" - by Hedd_Jones - 22-03-2019, 08:55 PM
RE: "cylinder head removal kit" - by Colin Wilks - 22-03-2019, 09:12 PM
RE: "cylinder head removal kit" - by Colin Reed - 23-03-2019, 01:12 AM
RE: "cylinder head removal kit" - by JonE - 23-03-2019, 10:03 AM
RE: "cylinder head removal kit" - by Stuart Giles - 23-03-2019, 12:45 PM
RE: "cylinder head removal kit" - by Ivor Hawkins - 23-03-2019, 05:28 PM
RE: "cylinder head removal kit" - by John Mason - 23-03-2019, 05:52 PM
RE: "cylinder head removal kit" - by Reckless Rat - 23-03-2019, 06:50 PM
RE: "cylinder head removal kit" - by Colin Reed - 23-03-2019, 08:49 PM
RE: "cylinder head removal kit" - by John Mason - 23-03-2019, 10:32 PM
RE: "cylinder head removal kit" - by Colin Wilks - 24-03-2019, 12:33 PM
RE: "cylinder head removal kit" - by Colin Ayre - 24-03-2019, 05:52 PM
RE: "cylinder head removal kit" - by Colin Morgan - 24-03-2019, 08:19 PM
RE: "cylinder head removal kit" - by John Mason - 24-03-2019, 09:14 PM
RE: "cylinder head removal kit" - by Chris KC - 25-03-2019, 04:03 AM
RE: "cylinder head removal kit" - by Andy Bennett - 25-03-2019, 09:05 AM
RE: "cylinder head removal kit" - by Colin Morgan - 25-03-2019, 12:45 PM
RE: "cylinder head removal kit" - by Chris KC - 26-03-2019, 12:46 AM
RE: "cylinder head removal kit" - by Hedd_Jones - 26-03-2019, 01:42 PM
RE: "cylinder head removal kit" - by Ivor Hawkins - 26-03-2019, 03:48 PM
RE: "cylinder head removal kit" - by JonE - 02-11-2019, 11:34 PM
RE: "cylinder head removal kit" - by Phil Kingdom - 03-11-2019, 01:16 AM
RE: "cylinder head removal kit" - by JonE - 03-11-2019, 10:23 AM
RE: "cylinder head removal kit" - by Colin Wilks - 03-11-2019, 11:11 AM
RE: "cylinder head removal kit" - by dickie65 - 03-11-2019, 02:14 PM
