gasket paper thickness
Hi Dennis,
It probably doesn't make any difference as the adjusters will take up any dimensional changes - as Tony suggests, if you've got a choice go for the thicker.
Other than head and the long manifold gaskets I make all my own. Christmas wrapping paper comes rolled up on a sheet of superb brown paper that makes great gaskets. It's very satisfying rubbing your slightly oily finger over the gasket paper to give an outline; punch out the holes with a wad punch first, then cut the internal holes with a curved pair of nail scissors and finally go round the outside of the gasket.
I've got the late big axle as well, I can't remember if the bolts are in blind holes or if you've got to seal them as well to keep the oil in?
Sounds like you're making progress with your axle, I hope it goes well.
Dave
gasket paper thickness - by Dennis Nicholas - 16-09-2017, 12:44 PM
RE: gasket paper thickness - by Tony Betts - 16-09-2017, 01:32 PM
RE: gasket paper thickness - by Speedex750 - 16-09-2017, 04:35 PM
RE: gasket paper thickness - by Ruairidh Dunford - 16-09-2017, 06:06 PM
RE: gasket paper thickness - by Tony Betts - 16-09-2017, 07:33 PM
RE: gasket paper thickness - by Ruairidh Dunford - 16-09-2017, 07:36 PM
RE: gasket paper thickness - by Ian Williams - 16-09-2017, 07:51 PM
