1938/39 and Big 7 back axle/shafts/nuts
If you need a box spanner for the large hub nut (I think from memory its 1 16/17 )it is the same size as a Harley Davison Flywheel, I got mine online from a company called Fecked (yes,really )
If you need a box spanner for the large hub nut (I think from memory its 1 16/17 )it is the same size as a Harley Davison Flywheel nut, I got mine online from a company called Fecked (yes,really )
RE: 1938/39 and Big 7 back axle/shafts/nuts - by Nigel Ricardo - 27-09-2018, 05:33 PM
